[gdal-dev] ogr2ogr changes field length
Even Rouault
even.rouault at spatialys.com
Thu Oct 7 08:59:05 PDT 2021
If you add -lco RESIZE=YES fields will be resized to their minimum size.
See https://gdal.org/drivers/vector/shapefile.html#layer-creation-options
Le 07/10/2021 à 17:40, matteo a écrit :
> Even,
> still a weird issue with the command. I'm using this command
> ogr2ogr -f "ESRI Shapefile" /home/matteo/myfolder "PG:dbname='mydb'
> host=myhost port=5432 user='myuser' password='mypws' sslmode=disable
> schemas='dati'" --config PG_USE_COPY YES --config PG_LIST_ALL_TABLES
> YES -progress'
> so without any append or overwrite (dumping a whole schema in a folder).
> I've both spatial and not spatial tables and for all of them the text
> fields are created in PG like:
> CREATE TABLE mytable (
> ID SERIAL PRIMARY KEY,
> NOTE text
> and all these fields are 80 characters long in the newly created
> shapefiles...
> I don't know if I can give some more information..
> Cheers and thanks
> Matteo
http://www.spatialys.com
