[gdal-dev] OpenFileGDB: Error occurred in filegdbtable.cpp at line 696
Ari Jolma ari.jolma at gmail.com
Tue Oct 12 02:40:10 PDT 2021
This works:
ari at xps:~/lahde$ ogrinfo -ro /vsis3/lahde-test-test/kuviot01102021.gdb
INFO: Open of `/vsis3/lahde-test-test/kuviot01102021.gdb'
       using driver `OpenFileGDB' successful.
1: kuviot (Multi Polygon)
2: invpsto_osite (None)
ari at xps:~/lahde$ ogrinfo --version
GDAL 3.3.2, released 2021/09/01
but with an older version (apt install gdal-bin in an ec2 machine)
ubuntu at ip-10-23-5-253:~$ ogrinfo -ro
ERROR 1: Error occurred in filegdbtable.cpp at line 696
FAILURE:
Unable to open datasource `/vsis3/lahde-test-test/kuviot01102021.gdb'
with the following drivers.
filegdbtable.cpp:696 is
    returnErrorIf(VSIFReadL( abyHeader, 40, 1, fpTable ) != 1 );
What might be the issue?
Ari
