[gdal-dev] HTTP response code: 303 from lpdaac.earthdata.nasa.gov
Joaquim Manuel Freire Luís jluis at ualg.pt
Tue Oct 12 03:00:15 PDT 2021
This seems to be related to some service change as it was working till yesterday and then started giving a 303 error.
Note that downloading the file with a browse, works.
gdalinfo /vsicurl/https://lpdaac.earthdata.nasa.gov/lp-prod-protected/HLSS30.015/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif --config GDAL_DISABLE_READDIR_ON_OPEN EMPTY_DIR --config CPL_VSIL_CURL_USE_HEAD FALSE --config GDAL_HTTP_COOKIEFILE c:/TEMP/cookies.txt --config GDAL_HTTP_COOKIEJAR c:/TEMP/cookies.txt
ERROR 11: HTTP response code: 303
gdalinfo failed - unable to open '/vsicurl/https://lpdaac.earthdata.nasa.gov/lp-prod-protected/HLSS30.015/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif'.
Joaquim
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211012/87fefb82/attachment-0001.html>
