[gdal-dev] HTTP response code: 303 from lpdaac.earthdata.nasa.gov
Even Rouault
even.rouault at spatialys.com
Tue Oct 12 03:05:19 PDT 2021
Joaquim,
FWIW, works for me with HEAD of master or 3.3 branch.
Even
Le 12/10/2021 à 12:00, Joaquim Manuel Freire Luís a écrit :
> Hi,
> This seems to be related to some service change as it was working till
> yesterday and then started giving a 303 error.
> Note that downloading the file with a browse, works.
> gdalinfo
> /vsicurl/https://lpdaac.earthdata.nasa.gov/lp-prod-protected/HLSS30.015/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif
> --config GDAL_DISABLE_READDIR_ON_OPEN EMPTY_DIR --config
> CPL_VSIL_CURL_USE_HEAD FALSE --config GDAL_HTTP_COOKIEFILE
> c:/TEMP/cookies.txt --config GDAL_HTTP_COOKIEJAR c:/TEMP/cookies.txt
> ERROR 11: HTTP response code: 303
> gdalinfo failed - unable to open
> '/vsicurl/https://lpdaac.earthdata.nasa.gov/lp-prod-protected/HLSS30.015/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif'.
> Joaquim
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211012/d0c0f8c9/attachment.html>
