[gdal-dev] HTTP response code: 303 from lpdaac.earthdata.nasa.gov
Joaquim Manuel Freire Luís jluis at ualg.pt
Tue Oct 12 03:31:08 PDT 2021
Hmm, that was in linux with a "GDAL 3.0.4, released 2020/01/28" but I get the same error on Windows with my build (< one month) of master.
The strange thing is that I was working in a script that downloads many of those files and between two iterations of bug fixes I started receiving that error.
Sent: Tuesday, October 12, 2021 11:05 AM
To: Joaquim Manuel Freire Luís <jluis at ualg.pt>; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] HTTP response code: 303 from lpdaac.earthdata.nasa.gov
Joaquim,
FWIW, works for me with HEAD of master or 3.3 branch.
Even
Le 12/10/2021 à 12:00, Joaquim Manuel Freire Luís a écrit :
This seems to be related to some service change as it was working till yesterday and then started giving a 303 error.
Note that downloading the file with a browse, works.
gdalinfo /vsicurl/https://lpdaac.earthdata.nasa.gov/lp-prod-protected/HLSS30.015/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif --config GDAL_DISABLE_READDIR_ON_OPEN EMPTY_DIR --config CPL_VSIL_CURL_USE_HEAD FALSE --config GDAL_HTTP_COOKIEFILE c:/TEMP/cookies.txt --config GDAL_HTTP_COOKIEJAR c:/TEMP/cookies.txt
ERROR 11: HTTP response code: 303
gdalinfo failed - unable to open '/vsicurl/https://lpdaac.earthdata.nasa.gov/lp-prod-protected/HLSS30.015/HLS.S30.T10TEK.2020273T190109.v1.5.B8A.tif'.
Joaquim
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211012/5c4afd22/attachment-0001.html>
