[gdal-dev] Failure to compile master
Joaquim Manuel Freire Luís
jluis at ualg.pt
Tue Oct 12 10:24:47 PDT 2021
I'm getting this error while building master (on Windows but shouldn't matter)
C:\programs\compa_libs\gdal_GIT\gdal\ogr\ogrspatialreference.cpp(7835): error C3861: 'proj_create_conversion_pole_rotation_netcdf_cf_convention': identifier not found
Found also this PROJ PR
https://github.com/OSGeo/PROJ/pull/2835
Does it mean we need to rebuild PROJ lib in order to build GDAL?
Joaquim
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211012/7debc3a6/attachment.html>
