[gdal-dev] Failure to compile master
Even Rouault even.rouault at spatialys.com
Tue Oct 12 10:29:14 PDT 2021
> Does it mean we need to rebuild PROJ lib in order to build GDAL?
Yes, this is a symbol new in PROJ 8.2dev, so when you use PROJ master,
you may need to rebuild GDAL if it depends on newer symbols.
> Joaquim
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211012/14076d2c/attachment.html>
