[gdal-dev] Export / import from PostGIS to GRASS and primary keys
Juan Pedro Pérez Alcántara
jp.perez.alcantara at gmail.com
Thu Oct 21 05:00:43 PDT 2021
Hi there,
I have some questions about the role of primary keys when importing /
exporting between PostGIS and GRASS. I've been making some tests regarding
this process and what follows are my impressions, so they may be wrong in
some points.
I fully understand that, given the disparity of data models,
simplifications needs to be taken regarding the very complex primary key
arrangements (multi column keys, for example) a Relational Database can do,
and that going through the GDAL pipeline with an integer autonumber ogc_fid
key is the sensible way to go, this is something that can be easily managed.
However, my workflow implies quite a lot of PostGIS ingested data that goes
to GRASS to perform topology cleaning and some other operations and back to
PostGIS. In this process, I've notice the following:
- GDAL ignores the primary key of the database, substituting it with an
ogc_fid, when importing into GRASS;
- when going back to PostGIS, another key comes from GRASS. I'm aware of
the FID option to rename the key.
My problem with this is that I lose in the process the original PostGIS
table PK. I'm workarounding this by making a physical copy of the PK into
another column, so when data is back, I can link original / GRASS processed
data.
Then, my question is: is there a way to keep the PK field at PostGIS into
the GDAL pipeline as a normal column, so I don't have to duplicate the
original PK as I'm doing right now?
Thank you so much, best regards,
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211021/51e7e408/attachment.html>
