[gdal-dev] gdallocationinfo + WCS question...
Carl Godkin
cgodkin at gmail.com
Thu Oct 21 08:47:18 PDT 2021
I am trying to use gdallocationinfo to query point locations from a WCS
server and not having any luck. I don't see anything in the docs that says
this is unsupported but I can't make it work.
First of all, is there a better way to get an elevation from a given
lat,lon using WCS?
Here's an example query using the USGS National Map server:
gdallocationinfo "WCS:
https://elevation.nationalmap.gov:443/arcgis/services/3DEPElevation/ImageServer/WCSServer?version=2.0.1&coverage=DEP3Elevation"
-wgs84 -122.086 42.948 --debug ON
This is a point in the middle of Crater Lake which I picked since it's flat
and I know what to expect.
Anyway, looking at the debug output it appears that the program is querying
for a GeoTIFF of a VERY large area and that's failing.
I actually want to do this with my own WCS server but thought it might be
mis-configured somehow so I tried the USGS server. With my own server,
gdallocationinfo seems to be requesting a strange shape from the server (as
I can see through the debug output).
Thanks for any help,
carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211021/5de32ec2/attachment.html>
