[gdal-dev] gdallocationinfo + WCS question...
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Thu Oct 21 11:16:48 PDT 2021
At least it seems to work with our WCS service
gdallocationinfo WCS:https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?version=2.0.1&coverage=korkeusmalli__korkeusmalli -wgs84 27 68
Report:
Band 1:
Value: 303.463989257812
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Carl Godkin
Lähetetty: torstai 21. lokakuuta 2021 18.47
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] gdallocationinfo + WCS question...
I am trying to use gdallocationinfo to query point locations from a WCS server and not having any luck. I don't see anything in the docs that says this is unsupported but I can't make it work.
First of all, is there a better way to get an elevation from a given lat,lon using WCS?
Here's an example query using the USGS National Map server:
gdallocationinfo "WCS:https://elevation.nationalmap.gov:443/arcgis/services/3DEPElevation/ImageServer/WCSServer?version=2.0.1&coverage=DEP3Elevation" -wgs84 -122.086 42.948 --debug ON
This is a point in the middle of Crater Lake which I picked since it's flat and I know what to expect.
Anyway, looking at the debug output it appears that the program is querying for a GeoTIFF of a VERY large area and that's failing.
I actually want to do this with my own WCS server but thought it might be mis-configured somehow so I tried the USGS server. With my own server, gdallocationinfo seems to be requesting a strange shape from the server (as I can see through the debug output).
Thanks for any help,
carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211021/5ef55f55/attachment-0001.html>
