[gdal-dev] gdallocationinfo + WCS question...
Ari Jolma ari.jolma at gmail.com
Thu Oct 21 12:08:36 PDT 2021
I don't understand the problem :)
Maybe it's because I ran gdalinfo on the WCS first.
For the gdallocationinfo I get
gdallocationinfo
"WCS:https://elevation.nationalmap.gov:443/arcgis/services/3DEPElevation/ImageServer/WCSServer?version=2.0.1&coverage=DEP3Elevation"
-wgs84 -122.086 42.948
Report:
   Band 1:
     Value: 1882.00549316406
Ari
Rahkonen Jukka (MML) kirjoitti 21.10.2021 klo 21.56:
> Hi,
> I wonder if the problem is in the multipart response that the
> nationalmap.gov server is sending. The result is not too big tiff
> (1023x511 pixels as revealed by <gml:high>1023 511</gml:high>) but
> perhaps GDAL does not know how to extract it from the multipart
> envelope. I do not know either. I thought that multipart was only an
> issue with WCS 1.1.x but obviously it can be used also with WCS 2.0. I
> do understand how brilliant idea multipart response is in theory but
> unfortunately it is a pain for the users.
> This is the beginning of the response:
> --wcs
> Content-Type: text/xml
> Content-ID: GML-Part
>   <gml:boundedBy>
>     <gml:Envelope srsName=http://www.opengis.net/def/crs/EPSG/0/3857
> <http://www.opengis.net/def/crs/EPSG/0/3857> axisLabels="x y"
> uomLabels=" " srsDimension="2">
>       <gml:lowerCorner>3005564.702644 10446506.055425</gml:lowerCorner>
>       <gml:upperCorner>3006588.702633 10447018.055420</gml:upperCorner>
>     </gml:Envelope>
>   </gml:boundedBy>
>   <gml:domainSet>
>     <gml:RectifiedGrid dimension="2" gml:id="grid_Coverage1">
>       <gml:limits>
>         <gml:GridEnvelope>
>           <gml:low>0 0</gml:low>
>         </gml:GridEnvelope>
>       </gml:limits>
> <gml:axisLabels>band_1</gml:axisLabels>
>       <gml:origin>
>         <gml:Point gml:id="grid_origin_Coverage1"
> <http://www.opengis.net/def/crs/EPSG/0/3857>>
>           <gml:pos>3005564.702644 10446506.055425</gml:pos>
>         </gml:Point>
>       </gml:origin>
>       <gml:offsetVector
> <http://www.opengis.net/def/crs/EPSG/0/3857>>XOFFSET1.000000XOFFSET 0
> </gml:offsetVector>
>       <gml:offsetVector
> <http://www.opengis.net/def/crs/EPSG/0/3857>>0 YOFFSET1.000000YOFFSET
> </gml:offsetVector>
>     </gml:RectifiedGrid>
>   </gml:domainSet>
>   <gml:rangeSet>
>     <gml:File>
>       <gml:rangeParameters xlink:href=cid:Coverage1.tif
> <cid:Coverage1.tif>
> xlink:role=http://www.opengis.net/spec/WCS_coverageencoding_geotiff/1.0/
> <http://www.opengis.net/spec/WCS_coverageencoding_geotiff/1.0/>
> xlink:arcrole="fileReference"/>
>       <gml:fileReference>cid:Coverage1.tif</gml:fileReference
> <cid:Coverage1.tif%3c/gml:fileReference>>
>       <gml:fileStructure/>
> <gml:mimeType>image/tiff</gml:mimeType>
>     </gml:File>
>   </gml:rangeSet>
>   <gmlcov:rangeType>
>     <swe:DataRecord>
>       <swe:field name="band_1">
>         <swe:Quantity>
> <swe:description>band_1</swe:description>
>           <swe:uom code="unknown"/>
>           <swe:constraint>
>             <swe:AllowedValues>
>               <swe:interval>3.4E-38 3.4E+38</swe:interval>
>             </swe:AllowedValues>
>           </swe:constraint>
>         </swe:Quantity>
>       </swe:field>
>     </swe:DataRecord>
>   </gmlcov:rangeType>
> </gmlcov:RectifiedGridCoverage>
> --wcs
> Content-Type: image/tiff
> Content-Description: coverage data
> Content-Transfer-Encoding: binary
> Content-ID: 1.tif
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta
> *Carl Godkin
> *Lähetetty:* torstai 21. lokakuuta 2021 18.47
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] gdallocationinfo + WCS question...
> Hi,
> I am trying to use gdallocationinfo to query point locations from a
> WCS server and not having any luck. I don't see anything in the docs
> that says this is unsupported but I can't make it work.
> First of all, is there a better way to get an elevation from a given
> lat,lon using WCS?
> Here's an example query using the USGS National Map server:
> gdallocationinfo
> <https://elevation.nationalmap.gov:443/arcgis/services/3DEPElevation/ImageServer/WCSServer?version=2.0.1&coverage=DEP3Elevation>"
> -wgs84 -122.086 42.948 --debug ON
> This is a point in the middle of Crater Lake which I picked since it's
> flat and I know what to expect.
> Anyway, looking at the debug output it appears that the program is
> querying for a GeoTIFF of a VERY large area and that's failing.
> I actually want to do this with my own WCS server but thought it might
> be mis-configured somehow so I tried the USGS server.  With my own
> server, gdallocationinfo seems to be requesting a strange shape from
> the server (as I can see through the debug output).
> Thanks for any help,
> carl
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211021/db01fbbf/attachment.html>
