[gdal-dev] gdallocationinfo + WCS question...
Even Rouault even.rouault at spatialys.com
Thu Oct 21 12:49:50 PDT 2021
Jukka,
I don't understand how you get a non-error on the below request on your
WCS service:
https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?SERVICE=WCS&REQUEST=DescribeCoverage&VERSION=2.0.1&COVERAGEID=korkeusmalli__korkeusmalli&FORMAT=text/xml
advertizes 3 bands
but the GeoTIFF returned by
https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?SERVICE=WCS&REQUEST=GetCoverage&VERSION=2.0.1&COVERAGEID=korkeusmalli__korkeusmalli&SUBSET=E%28498656,500704%29&SUBSET=N%287542384,7543408%29&Format=image/tiff
has just one band.
Or maybe you have in your ~/gdal/wcs_cache a previous version of the
DescribeCoverage response that advertizes just one band ?
And for what is worth,
gdallocationinfo
"WCS:https://elevation.nationalmap.gov:443/arcgis/services/3DEPElevation/ImageServer/WCSServer?version=2.0.1&coverage=DEP3Elevation
<https://elevation.nationalmap.gov:443/arcgis/services/3DEPElevation/ImageServer/WCSServer?version=2.0.1&coverage=DEP3Elevation>"
-wgs84 -122.086 42.948 --debug ON
returns 1882.00549316406 for me
The multipart answer doesn't seem to be an issue.
Le 21/10/2021 à 20:16, Rahkonen Jukka (MML) a écrit :
> Hi,
> At least it seems to work with our WCS service
> gdallocationinfo
> WCS:https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?version=2.0.1&coverage=korkeusmalli__korkeusmalli
> <https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?version=2.0.1&coverage=korkeusmalli__korkeusmalli>
> -wgs84 27 68
> Report:
>   Location: (228000P,119567L)
>   Band 1:
>     Value: 303.463989257812
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta
> *Carl Godkin
> *Lähetetty:* torstai 21. lokakuuta 2021 18.47
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] gdallocationinfo + WCS question...
> Hi,
> I am trying to use gdallocationinfo to query point locations from a
> WCS server and not having any luck. I don't see anything in the docs
> that says this is unsupported but I can't make it work.
> First of all, is there a better way to get an elevation from a given
> lat,lon using WCS?
> Here's an example query using the USGS National Map server:
> gdallocationinfo
> This is a point in the middle of Crater Lake which I picked since it's
> flat and I know what to expect.
> Anyway, looking at the debug output it appears that the program is
> querying for a GeoTIFF of a VERY large area and that's failing.
> I actually want to do this with my own WCS server but thought it might
> be mis-configured somehow so I tried the USGS server.  With my own
> server, gdallocationinfo seems to be requesting a strange shape from
> the server (as I can see through the debug output).
> Thanks for any help,
> carl
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211021/b08b2fcb/attachment.html>
