[gdal-dev] test failures on pkgsrc build of 3.3.2rc3
Greg Troxel
gdt at lexort.com
Wed Sep 1 09:27:10 PDT 2021
This message is not a request to hold 3.3.2. At this point, I don't
have any basis to believe that there's anything wrong with gdal, and I
haven't previously run the tests.
Thanks to Robert and Even for explaining about the test infrastructure.
I've addressed a few things
- packaging pytest-env
- work around tests possibly failing due to stale files by manual cleaning
(but that appears not to make any difference)
- temporarily removed the ogr_mitab test that leads to a python crash
which aborts the entire test run
and now have a test run that shows:
= 312 failed, 6939 passed, 1489 skipped, 2 xfailed, 2 warnings in 746.96s (0:12:26) =
which seems quite good overall.
Note that this my gdal was built with proj 6.3.2, partly old to avoid a
version with removed interfaces that other software needs, and partly
because I haven't gotten to dealing (in packaging) with the new proj
data layout. As I understand it, though, that's a supported version for
gdal, and the gdal build succeeds. I suspect if this does matter, it's
only for a few tests.
pkgsrc build log (showing configue output), driver list (from ogrinfo
failure), and test output at:
http://www.lexort.com/GDAL/
Looking into the avc failure, I find
$ ogrinfo ogr/data/avc/testavc/testavc/
INFO: Open of `ogr/data/avc/testavc/testavc/'
using driver `AVCBin' successful.
1: ARC (Line String)
2: LAB (Point)
But if I leave off the trailing / I get a failure to find a driver. A
trailing slash on a directrory name seems odd to me, and usually the
result of completion. I don't know if the slash mattering is right or
not and if it relates the test problems, but I see in the logs:
avc_ds = ogr.Open('data/avc/testavc/testavc')
> assert avc_ds.GetLayer(0).GetSpatialRef() is not None, 'expected SRS'
E AttributeError: 'NoneType' object has no attribute 'GetLayer'
where the open does not have trailing slash.
I do see AVCBin in my list of drivers.
Greg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210901/2710111e/attachment.sig>
