[gdal-dev] test failures on pkgsrc build of 3.3.2rc3
Greg Troxel
gdt at lexort.com
Wed Sep 1 12:22:30 PDT 2021
>> Looking into the avc failure, I find
>> $ ogrinfo ogr/data/avc/testavc/testavc/
>> INFO: Open of `ogr/data/avc/testavc/testavc/'
>> using driver `AVCBin' successful.
>> 1: ARC (Line String)
>> 2: LAB (Point)
>> But if I leave off the trailing / I get a failure to find a driver. A
>> trailing slash on a directrory name seems odd to me, and usually the
>> result of completion.
> Hum, I suspect you might hit a similar issue as the one for FreeBSD in
> https://github.com/OSGeo/gdal/blob/a95e796f65b26379b0e5c699bacef29f7684f79f/gdal/gcore/gdalopeninfo.cpp#L216
> where fopen("/some/dir", "rb") succeeds.
> Can you test changing that with whatever define is appropriate to test
> for your OS and submit the resulting patch ?
The comment about FreeBSD being odd seems strange to me, as POSIX has no
notion that fopen must fail when opening a directory for reading.
https://pubs.opengroup.org/onlinepubs/9699919799/functions/fopen.html
https://pubs.opengroup.org/onlinepubs/9699919799/functions/open.html
As I read the spec, it is a violation to return NULL when the first
argument is a directory and the second is r or rb. A test program
succeeds in calling fopen on . with rb, on both NetBSD and macOS 10.13.
Perhaps I am misreading the POSIX spec.
I applied a patch to always do the directory check, and now ogrinfo
works with or without the trailing /. Patch looks more complicated
than it is....
--- gcore/gdalopeninfo.cpp.orig 2021-09-01 09:48:45.000000000 +0000
+++ gcore/gdalopeninfo.cpp
@@ -213,12 +213,8 @@ retry: // TODO(schwehr): Stop using got
#endif // HAVE_READLINK
-#ifdef __FreeBSD__
- /* FreeBSD 8 oddity: fopen(a_directory, "rb") returns non NULL */
+ /* fopen(dir, "r") is required to succeed, per POSIX */
bool bPotentialDirectory = (eAccess == GA_ReadOnly);
-#else
- bool bPotentialDirectory = false;
-#endif // __FreeBDS__
/* Check if the filename might be a directory of a special virtual file system */
if( STARTS_WITH(pszFilename, "/vsizip/") ||
A test run with this fix and GDAL_DATA unset got to only 20 failures.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210901/0ddc7e95/attachment.c>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210901/0ddc7e95/attachment.sig>
