[gdal-dev] read ESRIJSON with ogr2ogr
Even Rouault
even.rouault at spatialys.com
Thu Sep 2 11:12:43 PDT 2021
Hugh,
I've queued in https://github.com/OSGeo/gdal/pull/4418 a fix for that.
But there's a simple workaround. Just remove the ESRIJSON: prefix in the
connection string. In that instance, the driver will be automatically
detected
Even
Le 02/09/2021 à 19:30, Hugh Kelley a écrit :
> Hi all,
> I'd like to load some data directly from an arcgis REST feature
> service using ogr2ogr.
> The command that follows collects exactly 5000 features, which i
> assume is the server limit mentioned in the ESRIJSON driver documentation
> ogr2ogr "streets.shp"
> ESRIJSON:"https://services1.arcgis.com/dLpFH5mwVvxSN4OE/arcgis/rest/services/Street_Centerlines/FeatureServer/0/query?where=objectid+%3D+objectid&outfields=*&f=json&orderByFields=OBJECTID+ASC
> <https://services1.arcgis.com/dLpFH5mwVvxSN4OE/arcgis/rest/services/Street_Centerlines/FeatureServer/0/query?where=objectid+%3D+objectid&outfields=*&f=json&orderByFields=OBJECTID+ASC>"
> -overwrite -oo FEATURE_SERVER_PAGING=YES
> Reading the documentation though, it sounds as though ogr2ogr should
> be paging through the feature service to collect the full set of
> features, which ogrinfo says number 10,954. Setting resultOffeset
> parameter to 5000 results in a new set of 5000 features. I have a lot
> of feature services to pull data from though so I'd like to be able to
> set ogr2ogr to page through the full feature set for each service
> rather than calculating the offsets and running multiple queries each
> time.
> Thanks for any suggestions.
> As a note, in case it makes a difference, I'm using shp here for
> simplicity but the actual destination will be a postgres db.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210902/b17f1bf2/attachment.html>
