[gdal-dev] XY Tolerance = 0 when creating layer in region settings with comma decimal separator
Javier Jimenez Shaw j1 at jimenezshaw.com
Fri Sep 3 09:39:52 PDT 2021
As Andrew suggested, I guess the proper value is 8983153e-15
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Fri, 3 Sept 2021 at 17:55, Karen M via gdal-dev <gdal-dev at lists.osgeo.org>
wrote:
> Hi Andrew,
> That's brilliant (not stupid at all)!  Option 3 ( XYTOLERANCE=8983153e-16)
> worked!!!!  Thank you so much!  I had already tried option 1 (using a
> comma), but that threw an error, and it never occurred to me to try
> scientific notation.  Thank you, thank you, thank you!
> Karen
> *Karen Meinstein*
> Product Support
> kbmeinstein at rothwellgroup.com | 303-261-8107 x 15
> <http://www.rothwellgroup.com/>[image: The Rothwell Group, L.P.]
> RothwellGroup.com <http://rothwellgroup.com> | PaleoGIS.com
> <http://paleogis.com> | BizRun.com <http://www.bizrun.com/>
> On Fri, Sep 3, 2021 at 1:07 AM Andrew C Aitchison <andrew at aitchison.me.uk>
> wrote:
>> On Thu, 2 Sep 2021, Karen M via gdal-dev wrote:
>> > Hi All,
>> > I'm using the C# bindings in gdal version
>> > release-1900-x64-gdal-2-4-3-mapserver-7-4-2.  When the operating system
>> > region settings are set to regions that uses a comma as the decimal
>> > separator and I use datasource.CreateLayer() to create a new file
>> > geodatabase layer, the resulting feature class has XY Tolerance = 0
>> when I
>> > use the layer in ArcGIS Pro.  When I use a region that uses decimal
>> points,
>> > the XY Tolerance is non-zero (which is correct).
>> > I've tried using the option "XYTOLERANCE=0.000000008983153" in
>> > CreateLayer(), but I still get XY Tolerance = 0.
>> Stupid suggestions; have you tried
>>    XYTOLERANCE=0,000000008983153
>>    XYTOLERANCE=8,983153e-10
>> or
>> (please double check the values 10 and 16) ?
>> Andrew C. Aitchison                                     Kendal, UK
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210903/81db4c16/attachment.html>
