[gdal-dev] XY Tolerance = 0 when creating layer in region settings with comma decimal separator
Karen M kbmeinstein at rothwellgroup.com
Fri Sep 3 08:55:17 PDT 2021
Hi Andrew,
That's brilliant (not stupid at all)!  Option 3 ( XYTOLERANCE=8983153e-16)
worked!!!!  Thank you so much!  I had already tried option 1 (using a
comma), but that threw an error, and it never occurred to me to try
scientific notation.  Thank you, thank you, thank you!
Karen
*Karen Meinstein*
Product Support
kbmeinstein at rothwellgroup.com | 303-261-8107 x 15
<http://www.rothwellgroup.com/>[image: The Rothwell Group, L.P.]
RothwellGroup.com <http://rothwellgroup.com> | PaleoGIS.com
<http://paleogis.com> | BizRun.com <http://www.bizrun.com/>
On Fri, Sep 3, 2021 at 1:07 AM Andrew C Aitchison <andrew at aitchison.me.uk>
wrote:
> On Thu, 2 Sep 2021, Karen M via gdal-dev wrote:
> > Hi All,
> > I'm using the C# bindings in gdal version
> > release-1900-x64-gdal-2-4-3-mapserver-7-4-2.  When the operating system
> > region settings are set to regions that uses a comma as the decimal
> > separator and I use datasource.CreateLayer() to create a new file
> > geodatabase layer, the resulting feature class has XY Tolerance = 0 when
> I
> > use the layer in ArcGIS Pro.  When I use a region that uses decimal
> points,
> > the XY Tolerance is non-zero (which is correct).
> > I've tried using the option "XYTOLERANCE=0.000000008983153" in
> > CreateLayer(), but I still get XY Tolerance = 0.
> Stupid suggestions; have you tried
>    XYTOLERANCE=0,000000008983153
>    XYTOLERANCE=8,983153e-10
> or
> (please double check the values 10 and 16) ?
> Andrew C. Aitchison                                     Kendal, UK
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210903/c60adf9e/attachment-0001.html>
