[gdal-dev] XY Tolerance = 0 when creating layer in region settings with comma decimal separator
Andrew C Aitchison
andrew at aitchison.me.uk
Fri Sep 3 00:06:53 PDT 2021
On Thu, 2 Sep 2021, Karen M via gdal-dev wrote:
> Hi All,
> I'm using the C# bindings in gdal version
> release-1900-x64-gdal-2-4-3-mapserver-7-4-2. When the operating system
> region settings are set to regions that uses a comma as the decimal
> separator and I use datasource.CreateLayer() to create a new file
> geodatabase layer, the resulting feature class has XY Tolerance = 0 when I
> use the layer in ArcGIS Pro. When I use a region that uses decimal points,
> the XY Tolerance is non-zero (which is correct).
> I've tried using the option "XYTOLERANCE=0.000000008983153" in
> CreateLayer(), but I still get XY Tolerance = 0.
Stupid suggestions; have you tried
XYTOLERANCE=0,000000008983153
XYTOLERANCE=8,983153e-10
or
XYTOLERANCE=8983153e-16
(please double check the values 10 and 16) ?
Andrew C. Aitchison Kendal, UK
