[gdal-dev] gdal-dev Digest, Vol 208, Issue 15
Elena Ruiz
eruiz at aplitop.com
Thu Sep 9 09:34:02 PDT 2021
Thank you very much for your answer, indeed when I add -oo EXTENT_METHOD = MOST_PRECISE_TILE_MATRIX to the gdalinfo command, it now works the same in both cases. But I have one more doubt, what would the correct syntax for Gdal.Open in c # look like? Thanks and regards
-----Mensaje original-----
De: gdal-dev <gdal-dev-bounces at lists.osgeo.org> En nombre de gdal-dev-request at lists.osgeo.org
Enviado el: jueves, 9 de septiembre de 2021 18:26
Para: gdal-dev at lists.osgeo.org
Asunto: gdal-dev Digest, Vol 208, Issue 15
Send gdal-dev mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.osgeo.org/mailman/listinfo/gdal-dev
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
gdal-dev-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of gdal-dev digest..."
Today's Topics:
1. Re: WMTS error with gdal2.4.4 (Even Rouault)
Message: 1
Date: Thu, 9 Sep 2021 18:25:37 +0200
To: Elena Ruiz <eruiz at aplitop.com>, "gdal-dev at lists.osgeo.org"
<gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] WMTS error with gdal2.4.4
Message-ID: <e9ffd23b-3964-c90b-ddfa-17088851394f at spatialys.com>
Content-Type: text/plain; charset="utf-8"; Format="flowed"
Elena,
the difference is likely due to the PROJ version used. I'd assume in the first case to be PROJ < 4.9.3 and in the second PROJ >= 4.9.3
You actually get a better result in the first case. If you add -oo EXTENT_METHOD=MOST_PRECISE_TILE_MATRIX, you should get the best result in any case
I've filed an issue https://github.com/OSGeo/gdal/issues/4461 about that
Even
Le 09/09/2021 ? 18:03, Elena Ruiz a ?crit?:
> Hello, I have two versions of GDAL 2.4.4 with the dll gdal204.dll
> dated 2020/01/08, but one is 17.4Mb and the other 20.3 Mb, with
> Gdal.VersionInfo I get the version of both files and is the same, but
> they give different results with the following command:
> DLL gdal204.dll (20,3 MB)
> >*gdalinfo
> "WMTS:http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=W
> MTS&username=&password=,layer=OI.OrthoimageCoverage,tilematrixset=EPSG
> :25830"*
> ERROR 1: latitude or longitude exceeded limits
> Driver: WMTS/OGC Web Map Tile Service
> Files: none associated
> Size is 20616192, 28663296
> Coordinate System is:
> PROJCS["ETRS89 / UTM zone 30N",
> GEOGCS["ETRS89",
> DATUM["European_Terrestrial_Reference_System_1989",
> SPHEROID["GRS 1980",6378137,298.257222101,
> AUTHORITY["EPSG","7019"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6258"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4258"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-3],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AXIS["Easting",EAST],
> AXIS["Northing",NORTH],
> AUTHORITY["EPSG","25830"]]
> Origin = (-1968157.094999999972060,7271532.000000000000000)
> Pixel Size = (0.149291070899963,-0.149291070899963)
> Metadata:
> ABSTRACT=Imagen de sat??lite Sentinel2 a escalas menores de 1:70.000 y
> las ortofotograf??as PNOA de m??xima actualidad para escalas mayores,
> para toda Espa??a. Las teselas se pregeneran en formato JPEG y hasta
> el nivel 19 (correspondiente con una escala aproximada 1:1.000) en el
> Sistema de Referencia por Coordenadas WGS84 Web Mercator (EPSG:3857).
> ? TITLE=Im??genes de sat??lite Sentinel y ortofotos PNOA
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left? (-1968157.095, 7271532.000) ( 45d 9'51.15"W,
> 57d59'16.66"N)
> Lower Left? (-1968157.095, 2992357.845) ( 27d 0' 0.04"W,
> 24d59'58.98"N)
> Upper Right ( 1109656.287, 7271532.000) ( 10d 0' 2.21"E, 65d 0'
> 0.77"N)
> Lower Right ( 1109656.287, 2992357.845) (? 3d 8' 0.50"E,
> 26d55'11.11"N)
> Center????? ( -429250.404, 5131944.922) ( 14d56'30.30"W,
> 45d42'45.53"N)
> DLL gdal204.dll (17,4 MB)
> >*gdalinfo
> :25830"*
> Size is 432948, 28663296
> GEOGCS["ETRS89",
> ?????AUTHORITY["EPSG","9122"]],
> UNIT["metre",1,
> Origin = (404318.828097780002281,7271532.000000000000000)
> Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left? (? 404318.828, 7271532.000) (? 5d 4'19.71"W, 65d33'
> 6.57"N)
> Lower Left? (? 404318.828, 2992357.845) ( 3d57'53.21"W, 27d 3' 0.59"N)
> Upper Right (? 468954.099, 7271532.000) ( 3d40'21.33"W, 65d33'52.09"N)
> Lower Right (? 468954.099, 2992357.845) ( 3d18'47.02"W, 27d 3'11.25"N)
> Center????? (? 436636.463, 5131944.922) ( 3d49'24.02"W, 46d20'17.22"N)
> As you can see, the command is exactly the same but in the first case
> an ERROR1 appears and also the coordinates are not the same as in the
> second case. What could the error be due to? Thanks and regards
> *Elena Ruiz *
> Sofware Development & Technical Support Tel. +34 952 43 97 71
> eruiz at aplitop.com Sumatra, 9 - 29190 M?laga (Spain) *www.aplitop.com
> <https://www.facebook.com/AplitopSL/> <https://twitter.com/aplitop>
> <https://www.linkedin.com/company/aplitop>
> <https://www.youtube.com/user/aplitop>*
> In accordance with the provisions of the European Regulation of Data
> Protection 2016/679 (Reglamento Europeo de Protecci?n de Datos
> 2016/679), we inform you that the data and the information you provide
> us through this medium will be used by APLITOP, S.L., with C.I.F.
> B-92543396 and with address at C / Sumatra, 9, Malaga, 29190, in order
> to answer your questions and inform you about our products. The data
> provided will be kept as long as it does not request its cessation and
> will not be transferred to third parties except in cases where there
> is a legal obligation. You have the right to access your personal
> data, correct inaccurate data or request its deletion when the data is
> no longer necessary for the purposes that were collected, as well as
> any rights recognized in the RGPD 2016/679
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/92fbf275/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/92fbf275/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/92fbf275/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/92fbf275/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/92fbf275/attachment-0003.png>
Subject: Digest Footer
End of gdal-dev Digest, Vol 208, Issue 15
