[gdal-dev] Maximum writable GDAL raster size (rows x columns and/or filesize in bytes)
Eric Patton
eric.r.patton at protonmail.com
Mon Sep 13 06:58:45 PDT 2021
I'm using MB-System to write very large GMT netCDF 4-byte float format rasters, and I need to know what is the maximum raster size I can write (rows x columns and/or filesize in bytes).
I had a large gdalwarp process running that was killed, probably on the order of several tens of thousands of rows and columns, but I can't tell if it was my operating system (Linux Mint 20.2) or GDAL that kiiled it.
Does GDAL impose any limits, and if so, what are they? How can I calculate what my operating system filesize limit would be?
Thanks,
Eric
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210913/775dddef/attachment.html>
