[gdal-dev] Maximum writable GDAL raster size (rows x columns and/or filesize in bytes)
Even Rouault
even.rouault at spatialys.com
Mon Sep 13 09:14:46 PDT 2021
Eric,
I would expect the limits to be beyond the capacity of any conceivable
hard disk. If you've a reproducer (you can possibly use the gdal_create
utility to create a dummy input file), please file a ticket about that
Even
Le 13/09/2021 à 15:58, Eric Patton via gdal-dev a écrit :
> Hi,
> I'm using MB-System to write very large GMT netCDF 4-byte float format
> rasters, and I need to know what is the maximum raster size I can
> write (rows x columns and/or filesize in bytes).
> I had a large gdalwarp process running that was killed, probably on
> the order of several tens of thousands of rows and columns, but I
> can't tell if it was my operating system (Linux Mint 20.2) or GDAL
> that kiiled it.
> Does GDAL impose any limits, and if so, what are they? How can I
> calculate what my operating system filesize limit would be?
> Thanks,
> Eric
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210913/53ff303b/attachment.html>
