[gdal-dev] Building mrsid autoload driver
Even Rouault even.rouault at spatialys.com
Mon Sep 20 12:48:06 PDT 2021
untested: If not already done, "apt install libgeotiff-dev"  and drop
the --with-geotiff switch
Le 20/09/2021 à 21:44, Craig Leat a écrit :
> Hi,
> I have gdal-3.0.4 installed on ubuntu 20.04. I require support for
> mrsid format.
> I wish to build the mrsid driver plugin only and hopefully avoid
> building gdal.
> I tried:
> $ cd src/gdal-3.0.4+dfsg/frmts/mrsid/pkg
> $ ./configure --with-gdal=/usr/bin/gdal-config
> --with-mrsid=/opt/MrSID_DSDK-9.5.4.4709-rhel6.x86-64.gcc531/Raster_DSDK
> --with-jp2mrsid=no --with-geotiff=../../gtiff/libgeotiff
> checking for lt_base.h in
> /opt/MrSID_DSDK-9.5.4.4709-rhel6.x86-64.gcc531/Raster_DSDK/include...
> found MrSID DSDK version 7.x or newer.
> checking for MG3ImageWriter.h in
> /opt/MrSID_DSDK-9.5.4.4709-rhel6.x86-64.gcc531/Raster_DSDK/include/mrsid_writers...
> no encoding support.
> checking for MrSID JPEG2000 support... disabled
> checking for XTIFFClientOpen in -lgeotiff... no
> checking for XTIFFClientOpen in -lgeotiff... (cached) no
> configure: error: libgeotiff is required to build GDAL MrSID driver
> Should this work?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210920/77619cc4/attachment.html>
