[gdal-dev] ModuleNotFoundError: No module named 'osgeo._gdal_array'
Even Rouault
even.rouault at spatialys.com
Fri Sep 24 06:14:24 PDT 2021
Lorenzo,
you didn't mention which Linux distro you used and how you installed numpy
I'm aware at least that on Alpine Linux, you need to install an
additional py3-numpy-dev package with the headers & lib needed to use
the C API of numpy, which is needed by the GDAL Python bindings
Check that the following returns something sensible
python3 -c "import numpy; print(numpy.get_include())"
when you build the GDAL python bindings look for the following messages
in the output that will indicate that the gdal_array module can't be built
"WARNING: numpy headers were not found! Array support will not be enabled"
or
'WARNING: numpy not available! Array support will not be enabled'
Even
Le 24/09/2021 à 14:53, Lorenzo Di Giacomo a écrit :
> Hi everyone, basically i build from source GDAL 3.2.2 and install the
> python bindings via pip3 install gdal==3.2.2
> Later i install numpy, i have read online that the numpy must be
> installed before GDAL python bindings.
> So i tried to uninstall python gdal and than reinstall it, but the
> problem still persists.
> Do you have any suggestions about it?
> Python3 libraries:
> GDAL 3.2.2
> NUMPY 1.21.2
> SWIG 4.0.2
> LOG:
> During handling of the above exception, another exception occurred:
> Traceback (most recent call last):
> File "temp-1544239507789228725main.py", line 98, in <module>
> SSRD,gtSSRD = tiff2array(path_to_tiff, band_SSRD)
> File "/hadoop/yarn/local/usercache/dispatcher/appcache/application_1628674283442_0030/container_e33_1628674283442_0030_01_000001/61a5101c-d78d-494d-b0d6-ef16719143719035222534140350861632485975806.zip/utility/rasterutils.py", line 58, in tiff2array
> File "/usr/local/lib/python3.7/site-packages/osgeo/gdal.py", line 3832, in ReadAsArray
> from osgeo import gdalnumeric
> File "/usr/local/lib/python3.7/site-packages/osgeo/gdalnumeric.py", line 2, in <module>
> from osgeo.gdal_array import *
> File "/usr/local/lib/python3.7/site-packages/osgeo/gdal_array.py", line 17, in <module>
> _gdal_array = swig_import_helper()
> File "/usr/local/lib/python3.7/site-packages/osgeo/gdal_array.py", line 16, in swig_import_helper
> return importlib.import_module('_gdal_array')
> File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
> return _bootstrap._gcd_import(name[level:], package, level)
> ModuleNotFoundError: No module named '_gdal_array'
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210924/3d166120/attachment-0001.html>
