[gdal-dev] ModuleNotFoundError: No module named 'osgeo._gdal_array'
Lorenzo Di Giacomo loridigia at gmail.com
Fri Sep 24 06:56:55 PDT 2021
Hi Even, my distro is:  Debian GNU/Linux 11 (bullseye)
Btw using pip3 install --force-reinstall gdal==3.2.2 --no-cache-dir works
fine.
Il giorno ven 24 set 2021 alle ore 15:14 Even Rouault <
even.rouault at spatialys.com> ha scritto:
> Lorenzo,
> you didn't mention which Linux distro you used and how you installed numpy
> I'm aware at least that on Alpine Linux, you need to install an additional
> py3-numpy-dev package with the headers & lib needed to use the C API of
> numpy, which is needed by the GDAL Python bindings
> Check that the following returns something sensible
> python3 -c "import numpy; print(numpy.get_include())"
> when you build the GDAL python bindings look for the following messages in
> the output that will indicate that the gdal_array module can't be built
> "WARNING: numpy headers were not found!  Array support will not be enabled"
> or
> 'WARNING: numpy not available!  Array support will not be enabled'
> Even
> Le 24/09/2021 à 14:53, Lorenzo Di Giacomo a écrit :
> Hi everyone, basically i build from source GDAL 3.2.2 and install the
> python bindings via pip3 install gdal==3.2.2
> Later i install numpy, i have read online that the numpy must be installed
> before GDAL python bindings.
> So i tried to uninstall python gdal and than reinstall it, but the problem
> still persists.
> Do you have any suggestions about it?
> Python3 libraries:
> GDAL 3.2.2
> NUMPY 1.21.2
> SWIG 4.0.2
> LOG:
> During handling of the above exception, another exception occurred:
> Traceback (most recent call last):
>   File "temp-1544239507789228725main.py", line 98, in <module>
>     SSRD,gtSSRD = tiff2array(path_to_tiff, band_SSRD)
>   File "/hadoop/yarn/local/usercache/dispatcher/appcache/application_1628674283442_0030/container_e33_1628674283442_0030_01_000001/61a5101c-d78d-494d-b0d6-ef16719143719035222534140350861632485975806.zip/utility/rasterutils.py", line 58, in tiff2array
>   File "/usr/local/lib/python3.7/site-packages/osgeo/gdal.py", line 3832, in ReadAsArray
>     from osgeo import gdalnumeric
>   File "/usr/local/lib/python3.7/site-packages/osgeo/gdalnumeric.py", line 2, in <module>
>     from osgeo.gdal_array import *
>   File "/usr/local/lib/python3.7/site-packages/osgeo/gdal_array.py", line 17, in <module>
>     _gdal_array = swig_import_helper()
>   File "/usr/local/lib/python3.7/site-packages/osgeo/gdal_array.py", line 16, in swig_import_helper
>     return importlib.import_module('_gdal_array')
>   File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
>     return _bootstrap._gcd_import(name[level:], package, level)
> ModuleNotFoundError: No module named '_gdal_array'
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210924/97a29a42/attachment.html>
