[gdal-dev] Does OAPIF paging work as supposed?
Even Rouault even.rouault at spatialys.com
Tue Sep 28 02:38:00 PDT 2021
Le 28/09/2021 à 09:04, Rahkonen Jukka (MML) a écrit :
> Hi,
> Even Rouault wrote:
> > One option to avoid both issues would be for the service to publish
> > DescribedBy links at the collection level that would point to a XML
> > schema (using a GML Simple Feature schema profile, such as the one
> > understood by the GML driver) or a JSON schema (not "too" complicated too).
> > Both are handled by the driver.
> We added JSON schema and ogrinfo seems to read it, but it still wants
> to read one page of data:
ah you're right. Yes, looking at the code it will always read one page.
There might be missing information in the schema, in particular for the
layer geometry type (not always filled in XML schema, and most likely
never in JSON schema, or at least the logic for that isn't implemented).
It also takes the opportunity to look at other things such as the
numberMatched information to be able to response to GetFeatureCount(),
although that could potentially be skipped and defered when it is invoked.
> ogrinfo
> OAPIF:http://some.internal.service/features/collections/PalstanSijaintitiedot/
> -al -so -oo PAGE_SIZE=10000 -nocount -noextent -nogeomtype --debug on
> HTTP: Fetch(http://some.internal.service
> /features/collections/PalstanSijaintitiedot/schema)
> HTTP: These HTTP headers were set: Accept: application/schema+json
> OAPIF: Using JSON schema
> /features/collections/PalstanSijaintitiedot/items?f=json&limit=10000)
> I wonder if there is still something in ogrinfo that I cannot turn off
> and what triggers the need to read some features, perhaps the
> coordinate system.
> -Jukka Rahkonen-
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210928/30cac38b/attachment.html>
