[gdal-dev] Memory allocation issues on Android 11+ and scudo
Andrew C Aitchison
andrew at aitchison.me.uk
Sat Apr 2 09:43:25 PDT 2022
On Sat, 2 Apr 2022, Philippe Lelong wrote:
> Thanks Even for taking the time.
> Note that the crash does not occur immediately. You have to load
> many S57s to get it. I do have an automatic procedure that crash
> always at the same time, but it is not a specific chart that crashes
> (= I can load the chart that crashes in the test loop without any
> problem, or if I change the order it will crash elsewhere but again
> always at the same place, with an out of memory error).
> My typical test is using Netherlands S57 charts
> (https://vaarweginformatie.nl/frp/main/#/page/infra_enc, take
> zeeland and nederland at the end of the page), and open/close them
> one by one in a loop.
Ah. Could the memory leak be in this loop ?
What language are you using ?
Andrew C. Aitchison Kendal, UK
