[gdal-dev] Create COG jpeg tiles with JFIF APPn markers
Even Rouault
even.rouault at spatialys.com
Tue Apr 5 08:15:51 PDT 2022
Jose,
> Those tiles contain normal JPEG markers (SOI, SOF0, DQT) but no JFIF
> marker (APP/n/) is added. How can I ensure adding this JFIF marker?
you can't, unless you're ready to patch the JPEG codec in libtiff to do that
I should point to
https://www.awaresystems.be/imaging/tiff/specification/TIFFTechNote2.txt
which mentions:
"Writers should avoid including "noise" JPEG markers (COM and APPn markers).
Standard TIFF fields provide a better way to transport any non-image data.
Some JPEG codecs may change behavior if they see an APPn marker they
think they understand; since the TIFF spec requires these markers to be
ignored, this behavior is undesirable."
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220405/14c72b64/attachment.html>
