[gdal-dev] GDALWarpAppOptionsNew and GDALWarp usage?
Even Rouault even.rouault at spatialys.com
Wed Apr 13 13:09:58 PDT 2022
Sean,
This looks fine, except for the argv[0] value, "lolwut". What is that
supposed to be ? I assume GDALWarpAppOptionsNew() fails on that and
returns NULL.
The obvious demo for using GDALWarp() is the gdalwarp binary itself:
https://github.com/OSGeo/gdal/blob/master/apps/gdalwarp_bin.cpp
The COG driver is also a user of it, perhaps more illustrative than the
above :
https://github.com/OSGeo/gdal/blob/master/frmts/gtiff/cogdriver.cpp#L552
Even
Le 13/04/2022 à 21:53, Sean Gillies a écrit :
> Hi all,
> I'm trying to figure out how to use the GDALWarp function from
> gdalwarp_lib.cpp. It looks like it takes a pointer to a
> GDALWarpAppOptions structure that is parsed from a string list,
> basically gdalwarp's argv, right?
> I'm able to get it to warp data, but the options, specifically the
> resampling option, don't seem to be passed into the warper. The output
> is the same for all resampling values.
> Here's my C usage (Cython, actually, but translates to C).
>     cdef GDALWarpAppOptions *warp_options = NULL
>     cdef char **argv = NULL
>     try:
>         argv = CSLAddString(argv, <const char *>"lolwut")
>         resampling_opt_value = Resampling(resampling).name # like
> "bilinear"
>         argv = CSLAddString(argv, <const char *>"-r")
>         argv = CSLAddString(argv, <const char *>resampling_opt_value)
>         CSLPrint(argv, NULL)
>         warp_options = GDALWarpAppOptionsNew(argv, NULL)
>         output_ds = GDALWarp(
>             NULL,
>             dst_dataset,
>             1,
>             src_datasets,
>             warp_options,
>             NULL
>     finally:
> The printed output, my argv, is
>     lolwut
>     -r
>     bilinear
> Does GDALWarpAppOptionsNew expect more values at the head of the
> command line? Is that why it is missing "-r"? Or is my string list
> made up of the wrong kind of strings? Documentation examples of
> building the arguments for GDALWarp are scarce. I'd be super grateful
> for help from anyone who has got code this to work.
> Thanks,
> Sean Gillies
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220413/023bbe2c/attachment.html>
