[gdal-dev] GDALWarpAppOptionsNew and GDALWarp usage?
Sean Gillies
sean.gillies at gmail.com
Wed Apr 13 13:36:03 PDT 2022
Thanks, Even!
When I checked the return of GDALWarpAppOptionsNew() and the error stack, I
found that the problem was that I'd been adding an unexpected "-wt
Unknown". After screening that out, I'm getting the resampling I expect.
On Wed, Apr 13, 2022 at 2:10 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Sean,
> This looks fine, except for the argv[0] value, "lolwut". What is that
> supposed to be ? I assume GDALWarpAppOptionsNew() fails on that and returns
> NULL.
> The obvious demo for using GDALWarp() is the gdalwarp binary itself:
> https://github.com/OSGeo/gdal/blob/master/apps/gdalwarp_bin.cpp
> The COG driver is also a user of it, perhaps more illustrative than the
> above :
> https://github.com/OSGeo/gdal/blob/master/frmts/gtiff/cogdriver.cpp#L552
> Even
> Le 13/04/2022 à 21:53, Sean Gillies a écrit :
> Hi all,
> I'm trying to figure out how to use the GDALWarp function from
> gdalwarp_lib.cpp. It looks like it takes a pointer to a GDALWarpAppOptions
> structure that is parsed from a string list, basically gdalwarp's argv,
> right?
> I'm able to get it to warp data, but the options, specifically the
> resampling option, don't seem to be passed into the warper. The output is
> the same for all resampling values.
> Here's my C usage (Cython, actually, but translates to C).
> cdef GDALWarpAppOptions *warp_options = NULL
> cdef char **argv = NULL
> try:
> argv = CSLAddString(argv, <const char *>"lolwut")
> resampling_opt_value = Resampling(resampling).name # like
> "bilinear"
> argv = CSLAddString(argv, <const char *>"-r")
> argv = CSLAddString(argv, <const char *>resampling_opt_value)
> CSLPrint(argv, NULL)
> warp_options = GDALWarpAppOptionsNew(argv, NULL)
> output_ds = GDALWarp(
> NULL,
> dst_dataset,
> 1,
> src_datasets,
> warp_options,
> NULL
> finally:
> The printed output, my argv, is
> lolwut
> -r
> bilinear
> Does GDALWarpAppOptionsNew expect more values at the head of the command
> line? Is that why it is missing "-r"? Or is my string list made up of the
> wrong kind of strings? Documentation examples of building the arguments for
> GDALWarp are scarce. I'd be super grateful for help from anyone who has got
> code this to work.
> Thanks,
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220413/f3d621cd/attachment.html>
