[gdal-dev] BAG CRS
Even Rouault
even.rouault at spatialys.com
Fri Apr 22 09:21:54 PDT 2022
André,
I don't confirm this trying:
$ gdal_translate autotest/gcore/data/byte.tif byte.bag
$ gdalinfo byte.bag -mdd xml:BAG | grep PROJCS
<gco:CharacterString>PROJCS["NAD27 / UTM zone
11N",GEOGCS["NAD27",DATUM["North_American_Datum_1927",SPHEROID["Clarke
1866",6378206.4,294.978698213898,AUTHORITY["EPSG","7008"]],AUTHORITY["EPSG","6267"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4267"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-117],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["EPSG","26711"]]</gco:CharacterString>
This is WKT1
I'm wondering if the confusion might come from looking at the CRS
reported by gdalinfo, which will always be WKT2 in recent GDAL versions
whatever the encoding in the source dataset itself ?
Or perhaps you try to write a Geographic 3D CRS ? in which case WKT2
will be used since there's no WKT1 representation for this
$ gdalwarp -overwrite autotest/gcore/data/byte.tif byte.bag -t_srs
EPSG:4979 -ot float32
$ gdalinfo byte.bag -mdd xml:BAG | grep GEOGCRS
<gco:CharacterString>GEOGCRS["WGS 84",ENSEMBLE["World
Geodetic System 1984 ensemble",MEMBER["World Geodetic System 1984
(Transit)"],MEMBER["World Geodetic System 1984 (G730)"],MEMBER["World
Geodetic System 1984 (G873)"],MEMBER["World Geodetic System 1984
(G1150)"],MEMBER["World Geodetic System 1984 (G1674)"],MEMBER["World
Geodetic System 1984 (G1762)"],MEMBER["World Geodetic System 1984
(G2139)"],ELLIPSOID["WGS
84",6378137,298.257223563,LENGTHUNIT["metre",1]],ENSEMBLEACCURACY[2.0]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,3],AXIS["geodetic
latitude
(Lat)",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["geodetic
longitude
(Lon)",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],AXIS["ellipsoidal
height (h)",up,ORDER[3],LENGTHUNIT["metre",1]], [... snip ....]
,ID["EPSG",4979]]</gco:CharacterString>
(I see that gdalinfo also issues a "ERROR 1: PROJ:
proj_create_compound_crs: components of the compound CRS do not belong
to one of the allowed combinations of
http://docs.opengeospatial.org/as/18-005r4/18-005r4.html#34" when
reading this, which I suspect comes from the fact that it tries to
create a CompoundCRS from this 3D GeogCRS and the "VERT_CS["unknown",
VERT_DATUM["unknown", 2000]]", so writing 3D GeogCRS isn't really
appropriate for BAG)
Even
Le 22/04/2022 à 18:01, Vautour, André (INT) a écrit :
> Hi all,
> It has just come to my attention that the BAG driver in GDAL is
> writing the CRS with a WKT codeSpace and a WKT 2.0 string as the code.
> While I am fairly sure we started that incorrect practice here at
> CARIS with a WKT 1.0 string, this is the first time I’ve seen a WKT
> 2.0 string written in there, and I am therefore concerned about
> interoperability.
> I think we can all agree that what makes the most sense is to write an
> EPSG codebase with the EPSG code if we have it, and I think falling
> back to a WKT 1.0 string if it is not EPSG is a reasonable fallback if
> it is not EPSG, given how it has been used in the past, but I am
> worried that older software won’t recognize the WKT 2.0 string.
> Would you be willing to take a pull request that does that?
> Worst-case, would you be fine with changing that WKT 2.0 string to a
> WKT 1.0 string?
> Regards,
> André
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220422/380beb12/attachment-0001.html>
