[gdal-dev] determine default SQL dialect
Michael Sumner mdsumner at gmail.com
Tue Aug 2 00:42:52 PDT 2022
Is it possible to determine the default SQL dialect  that will be used in
the C++ API?
It seems like the logic to pivot on dialect choice is only available to
drivers internally (they know if they have one), so a map of formats is
enough - but I wonder if I'm missing an API hook.
Also, there appears to be dialect values DEBUG, INDIRECT_SQLITE, MONGO_DB,
and ES in use but I gather they are for internal use (and so properly don't
appear in the documentation).
Thanks very much, Mike
Michael Sumner
Software and Database Engineer
Australian Antarctic Division
Hobart, Australia
e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220802/e2852f82/attachment.htm>
