[gdal-dev] csharp inverse transform problem
Gordon Paterson gordon at fatcyclops.com
Tue Aug 9 04:16:42 PDT 2022
Hi everyone,
GDAL 3.5.0
I have an application written in c# that takes data in WGS84 and transforms
the coordinates to the relevant local projected CRS.
In the code I use a URN with the EPSG transformation code, for example for
ED50 data -
urn:ogc:def:coordinateOperation:EPSG::1311
to convert between EPSG:4326 and EPSG:4230 and it works great for going
from EPSG:4230 > EPSG:4326 but it doesn't give the correct results the
other way.
Checking the coordinates with gdaltransform from the command line using the
following -
gdaltransform -s_srs EPSG:4326 -t_srs EPSG:4230 -ct
I get this -
WGS84 (EPSG:4326)
 2.25661712354279 56.4136492649363
ED50 (EPSG:4230)
2.25511244583886 56.4129769077511
which are the same coordinates I get through code, which is not right,  but
with the -i switch -
urn:ogc:def:coordinateOperation:EPSG::1311 -i
I get this -
ED50 (EPSG:4230)
2.25812179682132 56.414321584992
which is correct.
In the gdal docs there is a bReverseCT boolean parameter for
SetCoordinateOperation that is not accessible and is set to always be false
in the SWIG interface.
I set the correct Axis mapping on the spatial reference within code. I'm no
doubt missing something, what am I doing wrong?
thanks very much,
-Gordon
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220809/0137b96b/attachment-0001.htm>
