[gdal-dev] csharp inverse transform problem
Even Rouault
even.rouault at spatialys.com
Tue Aug 9 07:18:41 PDT 2022
Gordon,
urn:ogc:def:coordinateOperation:EPSG::1311 is from ED50 to WGS84, so
what you observe with gdaltransform is expected. You'd get the correct
result by just switching EPSG:4326 and EPSG:4230
Regarding the use of the API, it is true that this was lacking. Adressed
per https://github.com/OSGeo/gdal/pull/6175
Even
Le 09/08/2022 à 13:16, Gordon Paterson a écrit :
> Hi everyone,
> GDAL 3.5.0
> I have an application written in c# that takes data in WGS84 and
> transforms the coordinates to the relevant local projected CRS.
> In the code I use a URN with the EPSG transformation code, for example
> for ED50 data -
> to convert between EPSG:4326 and EPSG:4230 and it works great for
> going from EPSG:4230 > EPSG:4326 but it doesn't give the correct
> results the other way.
> Checking the coordinates with gdaltransform from the command line
> using the following -
> gdaltransform -s_srs EPSG:4326 -t_srs EPSG:4230 -ct
> I get this -
> WGS84 (EPSG:4326)
> 2.25661712354279 56.4136492649363
> ED50 (EPSG:4230)
> 2.25511244583886 56.4129769077511
> which are the same coordinates I get through code, which is not
> right, but with the -i switch -
> urn:ogc:def:coordinateOperation:EPSG::1311 -i
> I get this -
> ED50 (EPSG:4230)
> 2.25812179682132 56.414321584992
> which is correct.
> In the gdal docs there is a bReverseCT boolean parameter for
> SetCoordinateOperation that is not accessible and is set to always be
> false in the SWIG interface.
> I set the correct Axis mapping on the spatial reference within code.
> I'm no doubt missing something, what am I doing wrong?
> thanks very much,
> -Gordon
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220809/4d4fb7f2/attachment.htm>
