[gdal-dev] Python API ReadAsArray axis order
Chris Crook
ccrook at linz.govt.nz
Sun Dec 4 00:02:28 PST 2022
Hi
I am using the Python GDAL API and looking at a simple TIFF image with a test program:
from osgeo import gdal
dataset = gdal.Open('test-gdal.tif')
transform=dataset.GetGeoTransform()
nx=dataset.RasterXSize
ny=dataset.RasterYSize
data=dataset.ReadAsArray()
print(f"Raster xsize, ysize ({nx},{ny})")
print(f"ReadAsArray dimensions {data.shape}")
print(f"GeoTransform: {transform}")
The output is:
test_python_api.py
Raster xsize, ysize (3,4)
ReadAsArray dimensions (4, 3)
GeoTransform: (22.15, 0.7, 0.0, -69.5, 0.0, 1.0)
I am confused that the array appears transposed from the raster x,y size.
Is this always the cased. As far as I can tell the geotransform is assuming x,y (0-2,0-3 values) to map indices to location, which is what I want to do.
Can I assume that the array is always transposed? Or if not how do I identify when this is the case?
Many thanks in advance
Chris Crook
Land Information New Zealand
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221204/b69ba40a/attachment.htm>
