[gdal-dev] gdal_merge
Even Rouault
even.rouault at spatialys.com
Mon Dec 5 04:33:44 PST 2022
You may need to specify the pixel size with the -ps argument to be the
one with the less resolution.
Or try using gdalwarp instead (you may also need to use the -tr argument
to specify the resolution). gdal_merge cannot deal with rasters larger
than memory.
Le 05/12/2022 à 12:46, Clive Swan a écrit :
> Hi,
> The raster one is the world, the second is the UK.
> The UK fits within the first raster...
> We want to update UK data in raster one.
> Regards,
> Clive
> Get Outlook for Android <https://aka.ms/AAb9ysg>
> *From:* Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
> *Sent:* Monday, December 5, 2022 11:34:53 AM
> *To:* Clive Swan <cliveswan at gmail.com>; gdal-dev at lists.osgeo.org
> <gdal-dev at lists.osgeo.org>
> *Subject:* Re: [gdal-dev] gdal_merge
> Hi,
> Maybe your rasters are far apart. Gdal_merge creates a raster with so
> large extent that all the source images fit within it. Even empty
> pixels take space.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta
> *Clive Swan
> *Lähetetty:* maanantai 5. joulukuuta 2022 12.24
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] gdal_merge
> Hi Even,
> Thanks
> the –configuration sorted out that issue.
> CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE is a configuration option /
> environment variable, so you have to pass it with --config
> CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES
> Now I am getting a memory issue?? << The input files are 6.9 GB + 672 MB
> The output should be 7.xx GB
> 6.9 GB + 672MB
> numpy.core._exceptions._ArrayMemoryError: Unable to allocate 377. GiB
> for an array with shape (225000, 450000) and data type float32
> Any suggestions appreciated
> Kind regards,
> Clive
> Regards,
> Clive Swan
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221205/e2d2da31/attachment-0001.htm>
