[gdal-dev] gdal_merge
Andrew C Aitchison
andrew at aitchison.me.uk
Mon Dec 5 06:20:36 PST 2022
On Mon, 5 Dec 2022, Clive Swan wrote:
> The raster file details are:
> Extent: -180.0000000000000000,-90.0000000000000000 :
> 180.0000000000000000,90.0000000000000000
> Width: 7200
> Height: 3600
> Pixel Size = (0.000800000000000,-0.000800000000000)
> Data type: Float32 - Thirty two bit floating point
> Compression: LZW
> - Still getting an error for -ps 3600 7200
Maybe I misunderstand, but don't you want -ps 0.0008 0.0008 ?
> - I did not see gdalwarp option to merge two images
<dstfile>
The destination file name.
Mosaicing into an existing output file is supported if the
output file already exists. The spatial extent of the existing file
will not be modified to accommodate new data, so you may have to
remove it in that case, or use the -overwrite option.
So I would copy the world file then do something based on:
gdalwarp uk.tif world_copy.tif
Andrew C. Aitchison Kendal, UK
