[gdal-dev] Odd error
Clive Swan cliveswan at gmail.com
Sat Dec 10 05:19:40 PST 2022
I have been using the security details for weeks, now getting an odd error.
Getting an odd error??
I have been using the same:
AWS_ACCESS_KEY_ID
AWS_SECRET_ACCESS_KEY
ERROR 4: Attempt to create new tiff file `/vsis3/summer-outputs/1/coastal-
-2020.tif' failed: Permission denied
Input file size is 450000, 225000
ERROR 13: The specified key does not exist << ??
### Script below
#!/bin/bash
 LOG_FILE=/home/ubuntu/run_translate.log
 exec 1>>${LOG_FILE}
exec 2>>${LOG_FILE}
 ## 5_UK_prod_rasters >> 3_data_ready_for_spectra
gdal_translate /vsis3/summer-outputs /1/coastal -2020.vrt /vsis3/
summer-outputs /2/coastal -2020.tif -co BIGTIFF=YES  -co
NUM_THREADS=ALL_CPUS --config GDAL_CACHEMAX 100000 --config CPL_TMPDIR
/data/tmp --config CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES  --config
AWS_ACCESS_KEY_ID KEY_ID --config AWS_SECRET_ACCESS_KEY ACCESS_KEY
echo end script
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221210/fe25a8bd/attachment.htm>
