[gdal-dev] libtiff v4.5.0 release candidate available
Kai Pastor, DG0YT dg0yt at darc.de
Sun Dec 11 02:42:27 PST 2022
It is probably the best and cheapest what they could do with introspection.
The ultimate way out is to export CMake config in a compatible way so
that *future* versions of FindTIFF.cmake can use it. (This is already
done for CURL.) As a positive side-effect, this helps to properly carry
transitive usage requirements for static linkage and to deal with
multi-config generators.
Kai
Am 10.12.22 um 14:29 schrieb Even Rouault:
> Hi,
> annoying that FindTIFF.cmake is so formatting sensitive, but I've
> reverted the reformatting of that file in
> https://gitlab.com/libtiff/libtiff/-/merge_requests/434
> I've also added long overdue TIFFLIB_MAJOR_VERSION,
> TIFFLIB_MINOR_VERSION, TIFFLIB_MICRO_VERSION defines
> Even
> Le 10/12/2022 à 11:40, Kai Pastor, DG0YT a écrit :
>> Thanks for your work!
>> There is an issue with tiff_vers.h:
>> The new linebreak style of the TIFF_VERSION_STR definition breaks
>> version detection in CMake's FindTIFF.cmake,
>> leaving TIFF_VERSION unset (in CMake). Some packages rely on this
>> variable. E.g. openimageio in vcpkg:
>> -- Found TIFF
>> CMake Error at src/cmake/checked_find_package.cmake:154 (if):
>>   if given arguments:
>>     "VERSION_LESS" "4.0"
>>   Unknown arguments specified
>> Call Stack (most recent call first):
>>   src/cmake/externalpackages.cmake:90 (checked_find_package)
>>   CMakeLists.txt:141 (include)
>> which probably comes from some
>> if(${TIFF_VERSION} VERSION_LESS "4.0")
>> I would suggest to restore a formatting which doesn't break existing
>> CMake code.
>> Regards, Kai
>> Am 09.12.22 um 16:48 schrieb Even Rouault:
>>> Hi,
>>> I've prepared a release candidate for libtiff v4.5.0:
>>> - https://download.osgeo.org/libtiff/tiff-4.5.0rc1.tar.gz
>>> - https://download.osgeo.org/libtiff/tiff-4.5.0rc1.tar.gz.sig
>>> - https://download.osgeo.org/libtiff/tiff-4.5.0rc1.tar.xz
>>> - https://download.osgeo.org/libtiff/tiff-4.5.0rc1.tar.xz.sig
>>> - https://download.osgeo.org/libtiff/tiff-4.5.0rc1.zip
>>> - https://download.osgeo.org/libtiff/tiff-4.5.0rc1.zip.sig
>>> Release notes at https://libtiff.gitlab.io/libtiff/releases/v4.5.0.html
>>> I'll promote it to final next week if no serious blocking issues are
>>> reported.
>>> Thanks to all contributors.
>>> Best regards,
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
