[gdal-dev] ERROR 13: The specified key does not exist
Clive Swan cliveswan at gmail.com
Mon Dec 12 03:05:49 PST 2022
I reran the gdal_translate command using tif, not the .vrt. Now I get*
ERROR: *too many commands
I need to specify
-co BIGTIFF=YES -co COMPRESS=LZW -co BLOCKXSIZE=128 -co BLOCKYSIZE=128  -co
NUM_THREADS=ALL_CPUS --config GDAL_CACHEMAX 100000 --config CPL_TMPDIR
/data/tmp --config CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES
Any suggestions how I can implement the commands required??
 Regards,
Clive Swan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221212/772e4e5d/attachment.htm>
