[gdal-dev] ERROR 13: The specified key does not exist
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Mon Dec 12 03:09:06 PST 2022
Please show the whole command that you used. That way it is much easier to find out the error in your syntax.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Clive Swan
Lähetetty: maanantai 12. joulukuuta 2022 13.06
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] ERROR 13: The specified key does not exist
I reran the gdal_translate command using tif, not the .vrt. Now I get ERROR: too many commands
I need to specify
-co BIGTIFF=YES -co COMPRESS=LZW -co BLOCKXSIZE=128 -co BLOCKYSIZE=128 -co NUM_THREADS=ALL_CPUS --config GDAL_CACHEMAX 100000 --config CPL_TMPDIR /data/tmp --config CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES
Any suggestions how I can implement the commands required??
Regards,
Clive Swan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221212/6f26eaa8/attachment.htm>
