[gdal-dev] ERROR 13: The specified key does not exist
    Clive Swan
    cliveswan at gmail.com
    Mon Dec 12 06:24:42 PST 2022
Greetings,
The problem was writing directly from one AWS instance to another.
I have to write to the local instance, than copy to the other instance.
Thanks
Clive
On Mon, 12 Dec 2022 at 09:57, Andrew C Aitchison <andrew at aitchison.me.uk>
wrote:
> On Mon, 12 Dec 2022, Clive Swan wrote:
> > Greetings,
> > I have been using the security details for weeks, now getting an odd
> error.
> > AWS_ACCESS_KEY_ID
> > AWS_SECRET_ACCESS_KEY
> > *ERROR 4:* Attempt to create new tiff file
> `/vsis3/summer-outputs/3/coastal-
> > -2020.tif' failed: Permission denied
> > Input file size is 450000, 225000*ERROR 13*: The specified key does
> > not exist *<< ??*
> Does it really say coastal--2020.tif with two dashes ?
> > *### Script below*
> > #!/bin/bash
> > LOG_FILE=/home/ubuntu/run_translate.log
> > exec 1>>${LOG_FILE}
> > exec 2>>${LOG_FILE}
> > ## 5_UK_rasters >> 3_data_ready
> > gdal_translate /vsis3/summer-outputs/5/coastal-2020.vrt /vsis3/
> > summer-outputs/3/coastal-2020.tif -co BIGTIFF=YES  -co
> > NUM_THREADS=ALL_CPUS --config GDAL_CACHEMAX 100000 --config CPL_TMPDIR
> > /data/tmp --config CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES
> > --config AWS_ACCESS_KEY_ID KEY_ID --config AWS_SECRET_ACCESS_KEY
> > ACCESS_KEY
> > echo end script
> Andrew C. Aitchison                      Kendal, UK
 Regards,
Clive Swan
M: +44 7766 452665
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221212/22e92ebc/attachment.htm>
