[gdal-dev] ERROR 13: The specified key does not exist
    Michael Smith
    michael.smith.erdc at gmail.com
    Mon Dec 12 06:29:09 PST 2022
Clive,
A solution to this is to use a GDAL configuration file that will allow you to set per path options for your authentication, allowing you to use one set of credentials for read and one for write. See https://gdal.org/user/configoptions.html#gdal-configuration-file
Starting with GDAL 3.5, a configuration file can also contain credentials (or more generally options related to a virtual file system) for a given path prefix, that can also be set with VSISetPathSpecificOption(). Credentials should be put under a [credentials] section, and for each path prefix, under a relative subsection whose name starts with “[.” (e.g. “[.some_arbitrary_name]”), and whose first key is “path”.
Mike
Michael Smith
US Army Corps of Engineers
Remote Sensing/GIS Center
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Clive Swan <cliveswan at gmail.com>
Date: Monday, December 12, 2022 at 9:24 AM
To: Andrew C Aitchison <andrew at aitchison.me.uk>, <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] ERROR 13: The specified key does not exist
Greetings,
The problem was writing directly from one AWS instance to another.
I have to write to the local instance, than copy to the other instance.
Thanks
Clive
On Mon, 12 Dec 2022 at 09:57, Andrew C Aitchison <andrew at aitchison.me.uk> wrote:
On Mon, 12 Dec 2022, Clive Swan wrote:
> Greetings,
> I have been using the security details for weeks, now getting an odd error.
> AWS_ACCESS_KEY_ID
> AWS_SECRET_ACCESS_KEY
> *ERROR 4:* Attempt to create new tiff file `/vsis3/summer-outputs/3/coastal-
> -2020.tif' failed: Permission denied
> Input file size is 450000, 225000*ERROR 13*: The specified key does
> not exist *<< ??*
Does it really say coastal--2020.tif with two dashes ?
> *### Script below*
> #!/bin/bash
> LOG_FILE=/home/ubuntu/run_translate.log
> exec 1>>${LOG_FILE}
> exec 2>>${LOG_FILE}
> ## 5_UK_rasters >> 3_data_ready
> gdal_translate /vsis3/summer-outputs/5/coastal-2020.vrt /vsis3/
> summer-outputs/3/coastal-2020.tif -co BIGTIFF=YES  -co
> NUM_THREADS=ALL_CPUS --config GDAL_CACHEMAX 100000 --config CPL_TMPDIR
> /data/tmp --config CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES
> --config AWS_ACCESS_KEY_ID KEY_ID --config AWS_SECRET_ACCESS_KEY
> ACCESS_KEY
> echo end script
Andrew C. Aitchison                      Kendal, UK
 Regards,
Clive Swan
M: +44 7766 452665
_______________________________________________ gdal-dev mailing list gdal-dev at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221212/018381b8/attachment.htm>
