[gdal-dev] gdalwarp running very slow
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Tue Dec 13 07:49:18 PST 2022
If you are still struggling with the same old problem could you please finally send the gdalinfo reports of your two input files which are this time:
coastal-2020.tif
5_UK_coastal-2020.tif
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Clive Swan
Lähetetty: tiistai 13. joulukuuta 2022 17.23
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] gdalwarp running very slow
Greetings,
I am running gdalwarp on a 6GB (output) and 600MB (input) tif image, the AWS Instance has approx 60 VCPU
It has taken over 6 hours so far - still running, is it possible to optimise this and speed it up??
gdalwarp -r near -overwrite coastal-2020.tif 5_UK_coastal-2020.tif -co BIGTIFF=YES -co COMPRESS=LZW -co BLOCKXSIZE=128 -co BLOCKYSIZE=128 -co NUM_THREADS=ALL_CPUS --config CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES
Regards,
Clive Swan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221213/e80c5a17/attachment.htm>
