[gdal-dev] gdalwarp running very slow
Clive Swan
cliveswan at gmail.com
Tue Dec 13 09:22:05 PST 2022
Greetings,
I am using the same files, I copied them from an AWS Bucket to a local AWS
Instance.
I tried gdal_merge << tries to create 300GB file
I tried gdal_translate ran but created 2.5 GB not 6.9 GB file
Now trying gdalwarp.
the gdalinfo is the same in both datasets:
coastal-2020.tif (6.9GB)
Driver: GTiff/GeoTIFF
Size is 450000, 225000
Coordinate System is:
GEOGCRS["WGS 84",
DATUM["World Geodetic System 1984",
ELLIPSOID["WGS 84",6378137,298.257223563,
LENGTHUNIT["metre",1]]],
PRIMEM["Greenwich",0,
ANGLEUNIT["degree",0.0174532925199433]],
CS[ellipsoidal,2],
AXIS["geodetic latitude (Lat)",north,
ORDER[1],
AXIS["geodetic longitude (Lon)",east,
ORDER[2],
ID["EPSG",4326]]
Data axis to CRS axis mapping: 2,1
Origin = (-180.000000000000000,90.000000000000000)
Pixel Size = (0.000800000000000,-0.000800000000000)
Metadata:
AREA_OR_POINT=Area
datetime_created=2022-11-14 18:05:14.053301
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=BAND
PREDICTOR=3
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"N)
Lower Left (-180.0000000, -90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"S)
Upper Right ( 180.0000000, 90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"N)
Lower Right ( 180.0000000, -90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"S)
Center ( 0.0000000, 0.0000000) ( 0d 0' 0.01"E, 0d 0' 0.01"N)
Band 1 Block=128x128 Type=Float32, ColorInterp=Gray
Description = score
NoData Value=-9999
Band 2 Block=128x128 Type=Float32, ColorInterp=Undefined
Description = severity_value
NoData Value=-9999
Band 3 Block=128x128 Type=Float32, ColorInterp=Undefined
Description = severity_min
NoData Value=-9999
Band 4 Block=128x128 Type=Float32, ColorInterp=Undefined
Description = severity_max
NoData Value=-9999
Band 5 Block=128x128 Type=Float32, ColorInterp=Undefined
Description = likelihood
NoData Value=-9999
Band 6 Block=128x128 Type=Float32, ColorInterp=Undefined
Description = return_time
NoData Value=-9999
Band 7 Block=128x128 Type=Float32, ColorInterp=Undefined
Description = likelihood_confidence
NoData Value=-9999
Band 8 Block=128x128 Type=Float32, ColorInterp=Undefined
Description = climate_reliability
NoData Value=-9999
Band 9 Block=128x128 Type=Float32, ColorInterp=Undefined
Description = hazard_reliability
NoData Value=-9999
5_UK_coastal-2020.tif (600MB)
GEOGCRS["WGS 84",
CS[ellipsoidal,2],
ORDER[1],
ORDER[2],
ID["EPSG",4326]]
Metadata:
AREA_OR_POINT=Area
hostname=posix.uname_result(sysname='Linux', nodename='ip-172-31-12-125',
release='5.15.0-1022-aws', version='#26~20.04.1-Ubuntu SMP Sat Oct 15
03:22:07 UTC 2022', machine='x86_64')
COMPRESSION=LZW
INTERLEAVE=BAND
PREDICTOR=3
Corner Coordinates:
Description = score
NoData Value=-9999
NoData Value=-9999
NoData Value=-9999
NoData Value=-9999
NoData Value=-9999
NoData Value=-9999
NoData Value=-9999
NoData Value=-9999
NoData Value=-9999
Regards,
Clive Swan
If you are still struggling with the same old problem could you please
finally send the gdalinfo reports of your two input files which are
this time:
coastal-2020.tif
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org
<https://lists.osgeo.org/mailman/listinfo/gdal-dev>> Puolesta Clive
Swan
Lähetetty: tiistai 13. joulukuuta 2022 17.23
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] gdalwarp running very slow
Greetings,
I am running gdalwarp on a 6GB (output) and 600MB (input) tif image,
the AWS Instance has approx 60 VCPU
It has taken over 6 hours so far - still running, is it possible to
optimise this and speed it up??
gdalwarp -r near -overwrite coastal-2020.tif 5_UK_coastal-2020.tif
-co BIGTIFF=YES -co COMPRESS=LZW -co BLOCKXSIZE=128 -co BLOCKYSIZE=128
-co NUM_THREADS=ALL_CPUS --config
CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221213/9f56f652/attachment-0001.htm>
