[gdal-dev] Advanced 3.6.1 release and retraction of 3.6.0 ?
Howard Butler
howard at hobu.co
Tue Dec 13 07:52:47 PST 2022
+1
> On Dec 13, 2022, at 9:47 AM, Daniel Morissette <dmorissette at mapgears.com> wrote:
> +1 for 3.6.1 with this fix.
> Daniel
> On 2022-12-13 10:18, Even Rouault via gdal-dev wrote:
>> Hi,
>> https://github.com/qgis/QGIS/issues/51188 has been brought to my attention. The issue is that the new background building of the RTree of GeoPackage files introduced in 3.6.0 didn't work well with committing transactions in between, which is easily triggered by ogr2ogr. All features were inserted but with default settings ~ 10% of them lacked an entry in the spatial index, which can be enough to break interactive display and workflows relying on spatial filtering. When using ogr2ogr, I believe the issue can only be seen when creating layers with more than 100 000 features, since that's the default value for the interval at which transactions are committed.
>> I've a fix ready in https://github.com/OSGeo/gdal/pull/6911. The fix itself is a simple two-liner: https://github.com/OSGeo/gdal/pull/6911/commits/3f5f6225fe82e0c2e0241e4f66bfb861cdf4fe9d
>> Given the status of GeoPackage being the default format for QGIS, I believe this is a severe enough issue to warrant an advanced 3.6.1 release, and an official retraction of 3.6.0.
>> Thoughts ?
>> Even
> Daniel Morissette
> Mapgears Inc
> T: +1 418-696-5056 #201
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
