[gdal-dev] Advanced 3.6.1 release and retraction of 3.6.0 ?
Even Rouault even.rouault at spatialys.com
Thu Dec 15 11:35:41 PST 2022
Question: now that 3.6.1 is out, what to do with the
osgeo/gdal:xxxx-3.6.0 docker images:
- keep them
- remove them
- alias them to the 3.6.1 ones which are now available ?
The same holds with source tarballs of 3.6.0 available on
download.osgeo.org/gdal/3.6.0 or as github release. Digging into
history, we retracted 1.7.0 in
https://trac.osgeo.org/gdal/wiki/DownloadSource#a1.7.0retracted-January2010
and as far as I can see in http://download.osgeo.org/gdal/old_releases/
, the 1.7.0 tarballs were also removed from download.
Even
Le 13/12/2022 à 16:18, Even Rouault via gdal-dev a écrit :
> Hi,
> https://github.com/qgis/QGIS/issues/51188 has been brought to my
> attention. The issue is that the new background building of the RTree
> of GeoPackage files introduced in 3.6.0 didn't work well with
> committing transactions in between, which is easily triggered by
> ogr2ogr. All features were inserted but with default settings ~ 10% of
> them lacked an entry in the spatial index, which can be enough to
> break interactive display and workflows relying on spatial filtering.
> When using ogr2ogr, I believe the issue can only be seen when creating
> layers with more than 100 000 features, since that's the default value
> for the interval at which transactions are committed.
> I've a fix ready in https://github.com/OSGeo/gdal/pull/6911. The fix
> itself is a simple two-liner:
> https://github.com/OSGeo/gdal/pull/6911/commits/3f5f6225fe82e0c2e0241e4f66bfb861cdf4fe9d
> Given the status of GeoPackage being the default format for QGIS, I
> believe this is a severe enough issue to warrant an advanced 3.6.1
> release, and an official retraction of 3.6.0.
> Thoughts ?
> Even
http://www.spatialys.com
