[gdal-dev] Advanced 3.6.1 release and retraction of 3.6.0 ?
Sebastiaan Couwenberg sebastic at xs4all.nl
Thu Dec 15 11:47:11 PST 2022
On 12/15/22 20:35, Even Rouault wrote:
> The same holds with source tarballs of 3.6.0 available on
> download.osgeo.org/gdal/3.6.0 or as github release. Digging into
> history, we retracted 1.7.0 in
> https://trac.osgeo.org/gdal/wiki/DownloadSource#a1.7.0retracted-January2010 and as far as I can see in http://download.osgeo.org/gdal/old_releases/ , the 1.7.0 tarballs were also removed from download.
Why try to scrub buggy releases from the history?
They are not infectious diseases that need to be avoided like the plague.
The release happened so the artifacts associated with it should remain,
because of a significant bug a new release was published sooner than
expected to reduce the time the latest release is affected.
Kind Regards,
Bas
  GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
