[gdal-dev] Advanced 3.6.1 release and retraction of 3.6.0 ?
Daniel Evans daniel.fred.evans at gmail.com
Thu Dec 15 12:48:21 PST 2022
Similar thoughts here, too. Thinking particularly of the Docker image, the
main use case for them is ensuring a reproducible build on the user's side.
Those using the `latest` tag (indicating they're not so bothered about
versions) will start building with 3.6.1 automatically anyway. Those who
have pinned builds to 3.6.0 presumably want to avoid unexpected changes -
and given it's short life, I expect those are users who follow GDAL quite
closely.
I also don't get the impression this is *significantly* worse than the
normal bugfixes we see with any release - minor bugs like coordinate
rounding and interpolation issues have affected plenty of raster datasets
in the past, but we wouldn't consider a retraction of all GDAL versions up
to that point.
Regards,
Daniel
On Thu, 15 Dec 2022 at 20:11, Greg Troxel <gdt at lexort.com> wrote:
> Even Rouault <even.rouault at spatialys.com> writes:
> > Question: now that 3.6.1 is out, what to do with the
> > osgeo/gdal:xxxx-3.6.0 docker images:
> > - keep them
> > - remove them
> > - alias them to the 3.6.1 ones which are now available ?
> Basically I'm with Bas on this.
> But even more strongly, do not alias 3.6.0 to 3.6.1.  If someone asks
> for 3.6.0, getting it is fine, and getting an error is ok, but getting
> something else is not ok.
> As a packger  I don't really care, because I was fortunate to still be
> waiting to get around to 3.6.0 (part cmake, part life in general, part
> being a little shy about .0).  So I will, when I get to it, go right to
> 3.6.1.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221215/281d1c87/attachment.htm>
