[gdal-dev] std::numeric_limits<int64_t>::min() vs LLONG_MIN
Kurt Schwehr schwehr at gmail.com
Fri Dec 16 15:40:33 PST 2022
What exact error are you getting?
On Fri, Dec 16, 2022 at 3:31 PM Paul Meems <bontepaarden at gmail.com> wrote:
> Hello List,
> We're trying to update MapWinGIS which is using the GDAL libraries from
> gisinternals.com
> Currently, we use the stable daily of December 9:
> *release-1928-gdal-3-5-mapserver-8-0*
> I'm using VS2019 (on Windows) to compile and I'm having issues with two
> lines in gdal_pam.h, around line 215.
> We need to change these two lines:
>    - constexpr int64_t GDAL_PAM_DEFAULT_NODATA_VALUE_INT64 =
>    std::numeric_limits<int64_t>::min();
>    - constexpr uint64_t GDAL_PAM_DEFAULT_NODATA_VALUE_UINT64 =
>    std::numeric_limits<uint64_t>::max();
> To
>    - constexpr int64_t GDAL_PAM_DEFAULT_NODATA_VALUE_INT64 = LLONG_MIN;
>    - constexpr uint64_t GDAL_PAM_DEFAULT_NODATA_VALUE_UINT64 = LLONG_MAX;
> I prefer not to alter the files from gisinternals.com. Is this what we
> can solve on our end?
> Is it related to the C++ version? We use these:
>    - ISO C++14 Standard (/std:c++14)
>    - ISO C11 Standard (/std:c11)
> Thanks for any advice.
> Paul Meems
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221216/cbe1ed35/attachment.htm>
