[gdal-dev] std::numeric_limits<int64_t>::min() vs LLONG_MIN
Paul Meems bontepaarden at gmail.com
Fri Dec 16 15:46:59 PST 2022
Thanks, Kurt for your response.
I'm getting a very vague error message:
E0040 expected an identifier.
Regards,
Paul
Op za 17 dec. 2022 om 00:40 schreef Kurt Schwehr <schwehr at gmail.com>:
> What exact error are you getting?
> On Fri, Dec 16, 2022 at 3:31 PM Paul Meems <bontepaarden at gmail.com> wrote:
>> Hello List,
>> We're trying to update MapWinGIS which is using the GDAL libraries from
>> gisinternals.com
>> Currently, we use the stable daily of December 9:
>> *release-1928-gdal-3-5-mapserver-8-0*
>> I'm using VS2019 (on Windows) to compile and I'm having issues with two
>> lines in gdal_pam.h, around line 215.
>> We need to change these two lines:
>>    - constexpr int64_t GDAL_PAM_DEFAULT_NODATA_VALUE_INT64 =
>>    std::numeric_limits<int64_t>::min();
>>    - constexpr uint64_t GDAL_PAM_DEFAULT_NODATA_VALUE_UINT64 =
>>    std::numeric_limits<uint64_t>::max();
>> To
>>    - constexpr int64_t GDAL_PAM_DEFAULT_NODATA_VALUE_INT64 = LLONG_MIN;
>>    - constexpr uint64_t GDAL_PAM_DEFAULT_NODATA_VALUE_UINT64 = LLONG_MAX;
>> I prefer not to alter the files from gisinternals.com. Is this what we
>> can solve on our end?
>> Is it related to the C++ version? We use these:
>>    - ISO C++14 Standard (/std:c++14)
>>    - ISO C11 Standard (/std:c11)
>> Thanks for any advice.
>> Paul Meems
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221217/eeada8f7/attachment.htm>
